Prop shaft seal queries
LurcherNZ
I have noticed oil dripping from my propshaft seal (it is very cold here at the moment, southern New Zealand).
The outboard is a 97 Johnson 30. Unfortunately I do not have a service manual.
My question is can I replace just the seal on the prop shaft without dismantling the gear case or replacing other seals? Or is it best o buy a whole gear case seal unit and go right through it?
I have had a skid around on the web and it looks like this is the correct kit?
http://bpi.ebasicpower.com/ebinfo.php?pn=GLM87680
If I just need to replace the seal does anyone know the part number?
I use the boat in saltwater, should I flush the gearbox (with kerosene?) or something to get rid of potential saltwater contamination? and how would I go about this?
many thanks
John
LurcherNZ
Re: Prop shaft seal queries
wow this disappeared down the order quick! can anyone advise?
