Model is an '82 Evinrude 55hp longshaft. I'm replacing the prop and have a question about lower unit health. The prop shaft has no radial runout and seems true. However, I can thrust the prop shaft in/out about 1/8". Is this normal? The Seloc manual gives no help about this type of spec. I do have "minor" water intrusion (barely starts to turn milky after about 20 hours of operation) which I suspect to be the shift rod seal. However, I'm curious if this thrust slop in the prop shaft is typical or indicates problems. Thanks....
