Bunnerrabbit
- Joined
- Apr 9, 2002
- 104
I have a 02 Carolina Skiff Semi V with a 60HP Yamaha and the only numbers I see on the prop is 13-G when I look up props for my motor they all come up with 12" pitch. Is my boat over propped or is that not a pitch number? when I am alone it runs great but when I get close to the boats weight limit of 1075LBS it does have problems getting on plane if people are sitting up on the bow and trying to get to the top speed. WOT with about 550LB load is 5950RPM but with a 1000LB load it will only get to 5000RPM. The last 1 1/2" of the throttle is just does not respond. Wondering how much speed I will loose dropping a pitch size? will it give me noticeable difference in power? Suggestions welcome. Let me add it is a stainless prop
