Prop size question
joleda
I am replacing my14/21 prop on my Volvo AQ225/275. I have a 15/21 to replace it with. What will this change as for as perfomance etc. on my '86 capri bowrider?
Thanx,
Dave
steelespike
Re: Prop size question
Assuming similar design I see little change.The fairly large diameter difference may result in an rpm reduction.If you were having venting(cavitation) problems it may help.I'd be interested to see your results.
bruceb58
What was your max RPM with the older prop?
