dustinsapple
- Joined
- Jul 8, 2020
- 30
I recently bought my first boat, its a 1988 Renken Cuddy Classic 2000 19FT.
OMC 4.3 Cobra Inboard/Outboard
I bought the boat with a cracked block so I removed the motor and rebuilt it with a newer block but reused all the marine parts and heads, flywheel, balancer etc.
Aftering tinkering with the boat a bunch afterwards to get it to run right, I have the timing set at 6* at idle, and it sits around 18* at 3000rpm. I don't have a digital timing light just a basic and had to use a piece of tape to mark out the degrees to transfer to the balancer with whiteout since it only has 1 TDC mark. So my timing is aprox due to the fact that I just took the circumference of the balancer divided by 360 and layed out marks onto the balancer with whiteout. I have good vacuum at idle (20HG) so I believe the carb is setup fairly well, and I do not hear any tapping or funny noises from the rocker arms.
I also had to use an electric fuel pump with my new block, package says 4-7psi and seems to be getting enough fuel.
Anyways, so WOT I am maxxing out at 4000RPM with 15x17 prop and reaching 37-38mph on the water. I read online that I should be able to achieve 4200-4600rpm with this 4.3L OMC.
My question is, is my prop the wrong size for this boat, it obviously came on the boat however I do not know if it is original to the drive or not. I do not have trim tabs so I can only trim up/down with the out drive. When I am WOT it does however plane out fairly well. I am looking to get a little bit more top end, and be able to run the motor WOT and reach the 42-4600RPM range. Do you think my 4000RPM max is related to the prop size?
I do not know the weight of my boat, but its sitting on a single axle no brake trailer so I highly doubt its more than 3500lbs
Thanks!
Thanks!
