Prop size
J&K
2003 larson 190 LXI MPI V6
alpha leg 2nd generation
I am thinking of getting a 4 blade stainless, not sure which one i want.
Right now there is a 14.25 x 21 pitch 3 blade aluminum on there now.
seems to work good both out of hole and top end speed.
Does anybody know which prop came with this boat from factory?
Thanks
Jeff
greekfreek
Re: Prop size
Not being a prop specialist, but I would say the one you have now. If you max out at what your rated wot rpm is then you have the right prop. Going to a four blade changes things alittle, the net is full of info on that, such as mercurymarine.com/propellers
