Re: Prop size
ok,, maybe i not measuring it right,, diameter is straight across a circle i believe & that is what i measured outside edge to outside edge, & i come up with about 12",,, how to you measure it?? & what do you mean by the PITCH & the Application ?? & yes that is the correct model # 75ELR77S ,, & yes i do know how to measure the back of the boat & that is 21" now where do i measure on the shaft to make sure it is a LONG SHAFT ???,, BY the way how do you come up with 2 measurements in the prop ?? 13 3/4 X 17 ,, or 11 3/4 X 17 the X & 17 are my Question too
