prop size?
mercrude
1981 15' rinker bowrider just took a 1981 mercury 70 hp ob off and put a 1990 Johnson 70 hp ob with power t/t how do I determine the prop size?
walleyehed
Re: prop size?
Guessing here, but I'd say add 2 inches in pitch because the merc was crank rated and the newer eng. is prop-shaft rated........ :)
walleyehed
Re: prop size?
I should have said this would be true as long as the gear ratios are simular.........Sorry!<br /> I'd still consider a 2" increase :) though...
