I have a 2000 Four Winns 180 Horizon F/S with a 130hp johnson. I have the stock prop on it which is a 3 blade aluminum 14 1/2 x 19. At WOT I am currently getting 42 MPH at 5200 RPM, using both dash gauges, not GPS. I believe the gear ratio to be 2.25:1 from what i found on the internet
I have two questions?
1. When i put the above numbers in a slip calculator it says that I have ZERO slip. I know this is wrong, could my tach be wrong. When I put in 5800 rpm in the slip calc. it says about 10% slip, which I believe to be more realistic.
2. I like to do wakeboarding and tubing and I was having trouble holding plane at low speeds (20 MPH) and was coming off plane in high speed turns while tubing, so I just purchased a used OMC Renegad offshore prop in 14 1/4 by 19. Do you think this prop will help?
