Tacklewasher
- Joined
- Sep 18, 2002
- 1,588
I've just put an Evinrude 115 on the back of an 18' Starcraft SS.
Same motor and props that I tried to figure out in this thread a while ago.
http://forums.iboats.com/showthread.php?t=178243
Different boat though.
Saturday with the stainless. 13X19 OMC prop. WOT of ~4800 rpm and speed of 38 mph (gps). I figure 12% slip but not happy with the max RPM. Could trim quite a ways up without it ventilating, but didn't really try.
Sunday with the 13X15 aluminum. WOT of 5800 rpm but speed of 34 mph (gps). Same load (me and the wife), motor not moved and only the prop changed. This gives me about 17.5% slip. Now I really played with the trim on this run and found I had to be almost at the tilt before I heard any ventilating. As I was pretty close to max rpm, I trimmed back in at any noise.
So my question is, why would the two props give such different slip numbers on the same setup? Does the stainless to aluminum make that much of a difference?
My plan is to raise the motor one hole as I really could not get either prop to ventilate when being aggressive with the trim. I really want to see the motor spin at least 5500rpm. If I can do that with the 19, I figure I should see 45 mph. If not, I'll try to find a 17 pitch prop.
Does prop size matter? Someone has a 13 1/4 X 17 prop for sale locally.
