Prop slip
blh1972
What is the accepted % of slip for a prop?
when I plug my numbers into prop calculator's it shows about 30% slip.
Don S
Re: Prop slip
Moving this to the prop forum.
rogerwa
Re: Prop slip
Not an expert here but it depends on what you are pushing. A displacement hull will have a larger slippage. I have a 25' pontoon. The 40hp motor prop gave a 40+%. When I upgraded to a 90hp, with a larger diameter it brought the slippage down to around 29%.
Again it depends on what your setup is.
rogerwa
Re: Prop slip
What are the other specs.. WOT, speed, prop size and pitch.. Etc?
blh1972
Re: Prop slip
14 3/4 x 15 stainless prop, 4800rpm, 29-31 mph (by gps).
gear ratio is 1.5 to 1
bekosh
Re: Prop slip
I use this - http://www.go-fast.com/Prop_Slip_Calculator.htm
With your numbers, I get a slip of 33% which seems high to me.
When I use my numbers,
Drive Ratio 1.5 to 1, Mirage Plus 14.625x21 SS prop, 4800rpm, GPS speed 57.5mph, I get 10% slippage.
From the go-fast page it says this about slippage.
Slip is never a negative number, and will range from 5% on a light cat to 25% on a heavy workboat. Most hi performance applications will be between 7 and 12 percent.
MikDee
Banned
Re: Prop slip
If you have a 350 Vortec in there as in your signature, I think you might benefit from a 17" pitch prop, it will drop your rpm down I'd say into the recommended 4200-4600rpm range, and pick up some speed, with less slip.
rogerwa
Re: Prop slip
Again not an expert here. You may try different props with a larger diameter (more blade surface) or cup (better bite) or both to see if it impacts your numbers. If you look at the prop finder here on Iboats you see a number of props for that application that are 15"+. Also without knowing what prop is on there, its hard to know if it is cupped or not.
Experimenting would definitely be worth the trouble since you could gain 6-7 mph if you were to bring it to 15%.
Also, is the hull weight the listed dry weight or is this measured with fuel, gear, water, etc. You may running well in excess of 5500lbs.
QC
Re: Prop slip
This is why many heavier cruisers are set up with Bravo 2s. In this case, diameter is called for . . . ;)
blh1972
Re: Prop slip
So I should try a larger diameter prop in the same pitch?
How big can I go with the alpha one drive?
blh1972
Re: Prop slip
Thanks guys for the responses.
I will try a larger diameter inthe same pitch.
Does anyone know the max diameter for an alpha 1 outdrive.
rogerwa
Re: Prop slip
I don't know the max, but if you browse the prop for your application there are some 16" diameters in there. Maybe they sacrifice some of the exhaust for diameter.
You may be even able to handle going up an inch in pitch. One inch theoretically would drop your RPM by 200 but give you more speed. I just don't know how the incresed diameter will impact RPM.
MikDee
Banned
Re: Prop slip
Thinking about it, it does seem logical to inrease diameter, but it will drop rpm, so now I wouldn't recommend an increase in pitch. I've had good luck with Mercruiser props, over Michigans, but I know they're more expensive.
