Re: prop slipping suzuki dt 40
Hi Macbriar<br />From your info it sounds like the gearbox clutch dogs skipping, you probably feel several points of contact as you rotate the prop with the engine stationary. (however be gentle and rotate prop while engaging gears if the engine is not running, its very bad to change gears with a stationay engine). Normally it is reverse that gives up so you problem may be as simple as a misadjusted gearshift cable or linkage no selecting enough forward movement . Skipping damages the cogs so be sure to resolve your problem now.<br />Good luck<br />Sirlespat
