Prop Sticking
jonny rotten
I just got my boat.If I go out and try to spin the prop it feels as if its frozen.With minimal effort it will break free then spin normally.If I go out a few hours later it spins freely.Then if I leave it for a day or two its stuck again.While it spinning it makes a slight rubbing or grinding sound.I doesn't sound horrible,but doesnt sound smooth like a greased bearing either
ENSIGN
Re: Prop Sticking
Take the prop and thrust washer off and clean EVERYTHING probably fishing line and sand causing the issue
Re: Prop Sticking
I just got my boat.
Ayuh,... Fine, 'n Dandy, ya got a Boat.... What motor,..?? What Drive,..??
Re: Prop Sticking
Ok, the follow what Ensign said, 'n pull the prop, 'n Look...
It could be ole fishin' line, or possibly the wrong thrust hub....
