I have a 1987 stratos 181-pro 18'1" 92" beam probably around 2200-2400# fully loaded & I am running a newly rebuilt 2000 Johnson J150splssc 150 V6 gear ratio of 14:26 (.540) is what book says. motor 3 1/2" below the pad w/ a 6" jackplate. I currently have a 3 blade 20PX14 1/2" raker prop & motor is turning 5800-5900 motor trimed up at a speed of 55-57 mph on speedometer. Boat is completely restored (with some help from the guys in the building forum...Thanks so much for input) so it is not water logged or heavier than it would have been new. This is the prop I ran on my old 140 & I am not sure what to run on this one. It planes very quick. How far should you trim a set up like this up, or should you not trim it at all? Do I need a water pressure gauge. Any opinions would be greatly appreciated.
