Re: prop suggestion please
I'd start with probably a 19 to try. I'd say that with your Turbo lift you can run some extra X dimension (height) so you might be able to swing more.
A couple of thoughts -
is this the Bayhawk model with the true tunnel in it?
By any chance is there a small C or CR on the end of the proshaft where the nut goes? (look close)
