I have a Cobalt 200 w/4.3 LX merc. in it. I only use the boat maybe 2 weeks a year to go to the Keys, so any speed data is by memory from last year.
I have tried the stock 13.75 X 21,
a Powertech (?) 4 blade stainless - maybe 20P,
a Solas 15.3 X 19 aluminum,
a Solas 15.3 X 21 alum.
The stock - bad hole shot, not enough lift - esp. bow.
The 4 blade - alright hole shot, not enough lift - in fact seemed to push bow down.
The Solas 19P - nice hole shot, almost perfect lift, rpms 4800 or so, mph 48 or so.
The Solas 21P - not bad holeshot or lift, rpms down to 4500 or mph still 48 or so.
Ok I like the Solas 19P, but it seems to be worn some and didn't carry the bow like it used to (last year). I am assuming I need a big blade prop similar to the Solas.
ONLY gripe on the Solas's is at cruise 25mph/3000 rpms or so, I get a vibration/noise - seems like prop blades flexing some due to loading. It could use a little more bite also to carry the bow under light throttle and rougher water.
Ok question IS, should I
A. have the 21P repitched - it is new
B. just get another 19P Solas - or repaired again
C. is there a different model prop that will give me the lift I need (mainly to just get the hull out of the water in rougher seas), but be stronger/more rigid than the Solas? (stainless, 4 blade, new Solas Rubex?
I think I need a big blade prop (not dia. but rather blade)for that, correct?
I know I didn't give all of the info needed, but my memory just isn't what it used to be
