Re: Prop Swap!
No I am not sure, if its square bored. I baught the prop from ebay which was a mistake in the first place the seller said it would fit an alpha one with the 15 spline shaft, but It doesn't fit nearly at all like, my aluminum prop does. If it doesn't have the square bore, would it be possible to get the right pressed in rubber hub?
