Prop Testing Result Template - FYI
tahoejag
IBoaters's......had some spare time and typed up a template for recording prop testing results. I realize it gives general info, and could be edited, (the portion about the tabs is for my use for I have smart tabs). May save some writing time and would imagine could be copied and tailored to one's needs! :)
  • PROP TESTING RESULTS.pdf
Texasmark
Re: Prop Testing Result Template - FYI
Only thing missing, for my boat, would be trim position which is purely arbitrary. My trim position could make a serious impact on the results posted on that form. I guess you could run each test more than once. Run it first, in the range desired and tweak the variables for best response. Then run the test for time.
Mark
