Re: prop tricks
When you punch the throttle you get a blast of exhaust from the engine. Before the boat starts moving fast(er) there is actually a pressure inside your prop because it's full of water. This water in your prop hub creates resistance and the exhaust air it blown out the holes over the face of each trailing blade. Air on the blade face lets it slip,(ventilate) same as slipping a clutch on your truck to pull a heavy boat up a ramp. This gets the rpm up so she has more torque. After the boat is on plane and moving the prop hub is actually under a vacuum. As the boat moves through the water it actually pulls the exhaust out of the hub and it stops pushing air out of the holes. This is why it only works at slow speed where you need it.<br /><br /> As in the pic Corm posted you see the hole just behind the leading edge of a blade. As the prop spins this hole feeds the following blade the air. This work is best done by a prop shop. Once you get a small set of holes punched the prop guy it's not hard to enlarge them yourself a 1/16" at a time. I'd go real easy on how much and fast to increase size. Each size should be tried with different loads in the boat.
