tboltmike
- Joined
- Aug 17, 2006
- 340
I have a 2009 130 ETEC on my 17.4' by 7' beam trihull. Total weight engine, fuel, persons, gear is about 1700 lbs.
I am using the prop from the original 1975 115 HP Johnnie, 13" x 17"p, 3 blade stainless. That engine WOT was about 5200 rpm and 38 mph.
This prop on the ETEC pushes 45 mph at 5800 rpm.
Used a propeller wizard program it is recommending a 13.25 dia with either 23 or 21 inch pitch.
This seems like a drastic change.
Most of my cruising is between 30 and 35 mph, but do enjoy occasional speed blasts.
Do you have a diameter and pitch recommendation?
Thanks, Mike
Thanks, Mike
