Prop value??
SumDumGuy
I picked this prop up the other day and was wondering if it had any value? Also, if it does where is a good place to send it off?
It says it is a 14.25x21, it is aluminum and it is also stamped with Mercury.
IT appears to be in good condition, no cracks but there is a little bit of blade wear (if I was to use it I would file and paint).
jkust
Re: Prop value??
Sorry, what do you mean by send it off? It is a dime a dozen, aluminum prop. If it were SS, it would have some intrinsic value.
steelespike
Re: Prop value??
Thats a pretty basic prop and it uses a removable hub. I think it resembles a Solas Rubex though I would think Solas or Rubex would appear on it somewhere Merc props usually have number beginning with 48.
Of course I've never seen a regular prop without the hub pressed in.
SumDumGuy
Re: Prop value??
So, are you saying the Au I found is actually Pb? :facepalm:
jkust
Re: Prop value??
Not exactly to that extent. Like I said though old props both aluminum and SS are a dime a dozen on craigslist. Just that the SS are more like 20 cents.
doyall
Re: Prop value??
Comparison shop on that auction site and you will discover what jkust is talking about.
