ssportsmfg
- Joined
- Oct 7, 2014
- 42
I have a 2001 Johnson 50hp 2 stroke 2 cyl. on a Lowe 17 SE bass crappie combo. I purchased it used late last summer. When I got it the tach was not working, and it had a Michigan wheel 11.75 x 17 prop on it.
Being that it was not a Johnson prop, I am guessing that it was a replacement prop. The Johnson book lists a 12.25 x 15 as the proper prop. I used a Solas prop calculator ( it listed my exact boat) to purchase a new prop before I got the tach replaced it selected the 12 x 17 as the proper prop, so I purchased the Solas 12 x 17 Amita 3 prop and installed it.
A few weeks later I found, purchased and installed a new Faria system tach. While running at WOT it only runs at 4000 RPM. This is about 700 rpm slower than the Johnson book lists as full power at 4500-5500 rpm at WOT. I do know that a higher pitch will slow the RPM down.
I can tell that the motor has been messed with as all the orange lock tight has been broken off all the throttle linkage screws, including the WOT stop. The roller pin on the first plate with the curved slot is not at the two arrows. which I am guessing is where it should be at idle?
So two questions, did the Solas calculator pick the wrong prop? Should I be running higher RPM at WOT ??? It seems to run fine, no hesitation or missing at WOT. Should I just leave it alone, or is it running too slow and causing strain at the lower RPM? It does run rough at idle. And should I adjust the throttle linkage to the two arrows on the plate?
Thanks for any and all help !
