prop will not turn?
tmabe
9.9 gamefisher,engine runs great,suspect prop is slipping, if this is the case should i be able to turn prop with pliers on center metal insert??p.s it wont model 225581998 prop numbers 477265-1
steelespike
Re: prop will not turn?
If you suspect prop is slipping draw a water proof line across the hub and run the boat and check the line. Generally if the prop is slipping it will stop pushing as you increase power.Assuming the motor is mounted correctly on the boat.
