prop
jethro66
hey guys wats up? I have a 1972 25 hp evinrude and i was wondering if i could still buy a new prop? I think it broke today .when its in gear i can turn the prop by hand and i could see were its connected with the pin its spinning .wat a money pit !! any sugestions??
OBJ
Re: prop
If your sure it's just spinning and the prop shaft is not, just get the prop rehubed. It's spun. Most prop shops will rehub props. Cheaper than a new prop.
jethro66
Re: prop
Can u still buy them? (prop?) im sure it needs to be re hubed.
jethro66
Re: prop
thankyou sir!! I go and re hub it !! Maybey ill find somethingelse to fix !! great site!!
jethro66
Re: prop
shear the pin how can i tell I did not take it off Explain?
OBJ
Re: prop
You have to pull the prop off. The shear pin or drive pin fits thru a hole in the prop shaft and a slot in the hub of the prop fits over the pin. If the pin is sheared or broke, the prop won't turn with the shaft.
jethro66
Re: prop
Hey guys wats up? Can u please guide me in how to remove to prop? I dont want to F--- it up. Do you need a special tool? I can get it rehubed for 60$ Canadian.Thankyou!!
jethro66
Re: prop
Ok I took the prop off and its the shear pin it does not need to be rehubed!!! wat do i neeed to do now wat pats do i need stupid me!!
rickdb1boat
jethro66
Re: prop
yep quarter inche by 1 7 16thsof a inch. can i machine one ddo U have to use washers as well thewre wasnt any on it?
iwombat
Re: prop
No washers, just a straight cylinder. I think they're 304 stainless, could be 316 also never looked too far into it.
ezeke
Re: prop
The part is designed to protect the gears. Get the part from a dealer or it will be too strong and you will waste your prop or ruin your gears.
8)
iwombat
Re: prop
I agree. The pin is designed to fail first before any of the more expensive pieces get damaged. They're cheap and readily available.
iwombat
Re: prop
I duct tape an extra sheer pin and kotter pin to the inside of the engine cover. It's been a real life-saver more than once.
KYHunter2
Re: prop
I don't know about your motor.
But, I recall, several of the smaller motors I've had.
Had a little rubber holder inside the cowling for a few extra shear pins.
When I was a kid, and not as carefull, as I could have been.
They sure saved alot of ROWING !! LOL.
KYHunter
