Prop?
monkey04
I have a 2004 210ssi chaparral 5.0L,it came with a 19p ss wide fan prop.over rives at 4800,can't get wot.bought 2 alum.turning point props 14 1/4x21 can get up to 53mph but no big push on the start.the 14 1/4x23 is about 51mph but low rpm.the wide fan ss 19p is about 52-54 mph but can open motor to full trottle rive limiter cuts motor out at 4800 rpm.just ordered a 14x20 4 blade alum.michigan wheel,do you think this will work?Going to have a collection of new props that's no good to me.THANX,ROY.
a70eliminator
Re: Prop?
It tough to find one prop that will satisfy you wot spec in all conditions, I like a prop that exceeds max wot when boat is unloaded just me in it, just don't ring it out ease up on throttle, that same prop with a boat load of riders and pulling a tube puts the wot rpm right in there. You have to prop for what you do the most with your boat.
