PROP
COLDWATER
HI GUYS, IWAS WONDERING IF ANYONE HAD A PROP CONFIGURATION OR IDEA WHAT WORKS BEST WITH3.0 LX 135-40hp I/O BRAVO I OD, PUSHING A 24' RIENELL. tHIS BOAT IS FAIRLY HEAVY BUT I GOT LOT OF RPMS AND ABOUT 20-25 MPH AT 5K RPM 1:98 RATIO ON OD. THE MERC IS NEW I BUILT IT LAST YEAR along with the OD. MOTOR HAS PLENTY OF POWER TO SPARE. I HAVEN'T GOT A CLUE ABOUT THE PROP TYPE OR PITCH WOULD BE NICE IF SOMEONE HAD A IDEA iCOULD TRY. THE DEALER SAYS IT'S THE RIGHT PROP BUT IT CAN'T BE. the lower ratio is good in the Cook Inlet waters of AK. for power but I :confused: could pull a tug.
rickdb1boat
Re: PROP
Not sure with the info given, but it looks like a 16" X 14" would be close on a heavy boat. What are you running now??
COLDWATER
Re: PROP
RB, your right it is a 16 x 14 what would you suggest for a littel more speed like i said i got plenty of power or rpms left at top speed.
JB
Re: PROP
Moving to I/O
rickdb1boat
Re: PROP
What are your RPM's right now at full throttle? You could try a 15-1/4 X 15" prop that will give you about another 200-300 RPM's and possibly some extra speed. But you are real close if 5K is yout top RPM right now.
Re: PROP
I think Merc. still makes the 16X16 round ear prop.....<br />That Might also get you a little lower RPMs....<br />You want to get your WOT down to 4400/4600RPMs......
