prop ?
russeller
would a prop be the problem in why i am not moving that fast i have a 40hp rude 1966
LubeDude
Re: prop ?
Maybe its arthritis, how old are you?? :p <br /><br />We really need a little more information.
russeller
Re: prop ?
at wop 5500 roms i am only get about 20 21 mph i dont know the pitch of the prop and i dont know where to find it but i would think on a 14 ft fiberglass glastron it would get around 30 35 mph
Brew2
Re: prop ?
Spun prop hub?<br /><br />You could take a marker of some sort and mark both the prop hub and prop itself so the two marks align.... run the motor at WOT for a bit, then check the marks to see if they are still algined. If not, prop hub is spun and needs replacing.<br /><br />Good luck!
Bass Runner
Re: prop ?
check and see if your boat is waterlogged, how deep are you running the motor?
walleyehed
Re: prop ?
Before I get nailed again....Is your speedo GPS, paddle wheel, or pitot tube.<br />Question #2, is it reving up higher than normal when getting on plane?
jimmbo
Re: prop ?
You are over revving, rpm range for that engine is 4000 to 5000 and these engines don't like to turn faster. What prop are you running? a 12in or 13in pitch would be correct on that boat. top speed should be about 25 to 27 mph.
russeller
Re: prop ?
i am running a pilet tube the speedo was on the boat and i put a new tube on it
walleyehed
Re: prop ?
jimmbo, if he runs THAT engine at 4500, it's gonna have more carbon under the rings than you can remove in a year of decarboning..<br />Russ, what I was getting at is I want to make sure you are getting an accurate reading on the speedo.<br />pitot tubes are known for getting a piece of fuzz, moss or crud of some sort in it and reading wrong..matter-fact, it's the most inaccurate there is.<br />Does this engine tend to rev high when coming out of the hole and then drop slightly in RPM after getting on plane???<br />Your RPM is real good at 5500, just want to make sure the prop isn't slipping on the hub.<br />Keep us posted.
russeller
Re: prop ?
took the speedo out and behold a peice of FUZZ thank you waleyhed
