Propeller 115hp 4 stroke 2008 Mercury
HDBartman
I have just bought a 115hp Merc 25" shaft and have it on a 1903 Trophy. We have just ben out to sea and found it very hard to get to the plane with 3 people and fuel. Went out with just driver and it got to the plane faster but still slow. The motor came with a 13 3/4" x 18" pitch prop. I have read some reveiws and with a similar boat to the trophy they were using 13? x 15" props. Anyone can maybe give me experience on this matter?
steelespike
Re: Propeller 115hp 4 stroke 2008 Mercury
Not an expert:: but its difficult to know exactly where your at without your max rpm and speed.After checking the 115 Etec(has lots of different boat performance reports) makes a great reference point.90% of their tests are running 17 in props planing times were between about 4 sec. and about 8 sec.
It would seem to me your over propped.Max rpm and speed will help figure.
HDBartman
3200-3400 RPM = 8 mph
4500 RPM = 20 mph takes about 30+ sec to get to here currently
steelespike
Is the bottom clean?
Check your manual my guess is your max rpm range is around 6,000.
If 4,500 is with just you aboard I think something is up with your setup.You better get your dealer to check things out.In order to get to 6,000 you would need something like a 11 inch pitch.Something you find on a pontoon boat.
Unless your boat is a real tub I would think you would end up with something like 15 to 17 inches.
