I had to replace my 1999 175hp Evinrude with a 2005 200hp (3.0l) Mercury Optimax. The company which rebuilt the Optimax sold me a 15 x 19 prop with the Flo-Torq hub. They also told me my 15 spline prop from my Evinrude would fit the Optimax, so I kept the prop from my Evinrude for a spare. The 15 x 19 prop at W.O.T allows me to reach the low end of the RPM range for w.o.t. My primary cruising rpms are 4000 to 4200. My boat is a Crestliner Eagle 2360 SST. I was going to put the prop form my Evinrude which is 15 x 17 on the Mercury to let the Mercury run a little higher rpm's but found out quickly that it doesn't fit Mercury's front thrust washer that current prop fits on. The prop from my Evinrude, the hub is pressed rather than being a Flo-Torq hub. My 1st question is can I use a prop with a pressed hub on the Mercury Optimax? Can I get the proper forward thrust washer the fit the prop from my Evinrude to the Mercury output shaft? Both props are stainless steel. The Mercury prop is a Mirage Plus and the prop I don't know who the manufacturer is on the prop I kept from my Evinrude. Any answers regarding interchangeability would be appreciated.
