Propeller is chipped
massimofinance
Hi all, the Prop on my Evinrude 115HP has a few chips, no more than three, total an inch long, by 1/8" deep in one of the vents. Do I need to replace the entire thing? If I do not, should I file them down so that it is a smooth line?<br /><br />Thanks<br /><br />MAX
rwcreigh1
Re: Propeller is chipped
i would replace the prop.it could cause some vibrations causing problems with the lower unit.dont take my advice wait for the x-perts.i may be wrong.
JB
Richard is not wrong, Max. You should replace the prop.<br /><br />Good luck. :)
Dhadley
I would assume its an aluminum prop. If so, I'd have it fixed at a prop shop and keep it as a spare for the ss prop I would buy.
massimofinance
Thanks guys. If I cannot afford to replace the prop, should I file/sand it even?
D
DJ
Guest
No. Doing what you're asking can also throw it off balance.<br /><br />Rebuilding a prop is usually much cheaper than a new one.
massimofinance
can you please suggest a place to have it rebuilt?<br /><br />Thanks!<br /><br />MAX
Dhadley
All local dealers (marine) are hooked up with prop shops. Any can give you a ballpark for rebuild.<br /><br />Just for kicks, what size is it?
rwcreigh1
just do not file it and use it with out getting it fixed.it is cheaper to wait and save for a new prop then a new lower unit.price them and see.good luck
Solittle
The diameter and pitch is usually stamped on the hub.
not to break in on this post but what kind of prop is better brass or aluminum?<br /><br /><br />Tuck
moderator1
Better for what???<br />Cost to rebuild, speed, looks, weight, etc....<br />I/O or small outboard???
just curious what the benifit to one over the other is.<br /><br />for an outboard application.<br /><br />I have an aluminum thats chipped- just like the above prop-<br /><br />so I switched with the prop on the spare motor that was brass, heavy and in nice shape.<br /><br />I was wondering what the difference was- did you increase horse by going to a lighter aluminum prop? Durability and cost?<br /><br />I thought there may be a prefrence or benifit to useing one over the other.<br /><br />Tuck-
chris in va
Frankly, if you don't hit a lot of sand/rocks when boating, I *highly* recommend a stainless prop, one size pitch deeper. <br /><br />For example, I had a 19' Caravelle with 302 and it came with a trashed aluminum prop. Two more Al props later, I bought this composite POS with replaceable blades. Then, at the advice of my local prop shop, I ponied up the $$$ for a nice stainless and HOLY COW my top end saw another 9mph. A year of running that and it looked brand-new, no nicks or anything. <br /><br />When I get the money ($135) I'm getting one for my 9.9.
