Re: Propeller match?
What is the present prop? al. or ss.21"?If both are ss the 19" will raise your rpm "about"300-400rpm.hole shot will improve.If you ski or carry heavy loads it will do better.Check that it doesn't exceed max rpm at wot(wide open throttle).
Just throttle back a little.
If you give us your present prop size,material, and the max rpm and speed
we may be able to tell better where your at.
