Propeller Play.
lmannyr
I have an ever so slight play when I wiggle the prop side to side. Is there a tolerance for this? Is it OK to use like this?
What should I do check etc?
Can someone link me to the thread with the service manuals?
Thanks!!
abj87
Re: Propeller Play.
Splines worn? Is the nut tightened to spec?
Don S
Re: Propeller Play.
Remove the prop and check the shaft.
Then with a dial indicator determine what "Very slight" is.
