Propeller Question
postjim
3.0 Liter Mercruiser Alpha I<br />17',6" Sea Ray 2000lbs.<br />21x14.25 Factory Prop<br /><br />Factory Prop bent to heck by a partially submerged 2x10x12 in a 20 mph run-in. Picked up remains of lumber and deposited on dry land back at ramp. Used to spend summers as a kid in my jon boat picking up trash in the lake. Does anyone do this sort of thing anymore?<br /><br />My boat has a release feature on the Alpha I outdrive so it popped up on impact but the prop and the anode were bent. Got back to the ramp limping. <br /><br />Bought a Hustler Aluminum prop(Same pitch and diameter), new hub, and a new anode(Had to replace the old one because the new prop wouldnt clear it).<br /><br />Questions: <br />Is it possible that the Hustler prop decreased the cavitation problem that I was formerly having? <br /><br />Is there more than visual inspection and test driving that I need to do to to ensure that the lower unit is ok?<br /><br />Can old propellers be repaired even if there is a slight tear in one of the blades?<br /><br />Thanks.
Spidybot
Re: Propeller Question
Welcome to our playground, Jim<br /><br />Yes, is it possible that the Hustler prop decreased the cavitation problem. Those props are very good value and may very well do this.<br /><br />Apart from visual inspection and test driving you could check the lower unit oil for water content (white creamy 'mayonnaise'). Most likely you won't find any. I think your drive did exactly what it was meant to: Saved you a lot of problems by giving way.<br /><br />Old propellers be repaired even if there is a slight tear in one of the blades, take it to a prop shop and let them look at it. Should serve as a spare prop, afterwards.
roscoe
Yes, I pick up debris when I see it. I fish some flowages and rivers that seem to be full of old wood. Its amazing to me that more boats don't come limping in.
postjim<br /><br />Yes to picking up trash... even around ramps<br />Yes on the prop repair. When you take it in to be repaired ask them to show you pictures of before and after work they have done.. better than I could ever explain here and you will be amazed <br /><br />Luck to ya<br />Link
postjim
Thanks you all.<br /><br />Another related question. I didn't usa a torque wrench to tighten the propeller, but I cranked it down pretty good. When I cut the throttle there is a temporary creaking/squealing (Not high pitched) sound. It doesn't happen under acceleration. <br /><br />Any thoughts?<br /><br />Jim
