Re: Propeller
You can straighten a prop blade but it must be done in small stages with multiple taps of the hammer. The blades are cast and if you try to work them too much, they will break or crack. Due to the nature of cast metal, if you work it gently, you are in essence cold forging and actually increasing the strength--as long as you don't over-do it. Just keep eyeballing it to match it to the other blades. You will find that with a little practice, you will be able to see and fix even small variations.
I like to use the end of a 2 x 4 as an anvil. Usually it is one of my engine stands.
