Re: Propeller
Thank you steele spike and boat1010, I just went to a sporting good store and got some advice from the clerk there and purchased one. I am new to the site and just learing how to navigate through it as well as boating too. I did not know what terms like pitch on a prop, WOT etc meant I was just looking for some quick help so I could take my grandson fishing. I read that this was a family site so I did not think it was such a big deal. I was taken back a bit that I would be treated like a two year old for not using the site correctly or posting appropriate intake data for a solution.
Anyway I went to a 4 blade prop, from what I could find out the four blade cuts a bit on vibration. The 19 pitch was within normal limits for the boat, but the clerk suggested that when going to a four blade to go to a 17 pitch. As far as the hesitation upon quick acceleration I found two fuel filters on this mercruiser 140, its either a 1984 or 1986. One is on the fuel pump and the other is in the carb. The filter on the carb was totally clogged. After replacing them hesitation is no problem. I just have one more issue to deal with so I you have any suggestions please post back to me. This engine has a vent near the starter motor bendix/gear. There is fresh oil spewing from this vent when the engine is running. I found one oil leak on the valve cover gasket and replaced it, no more leaks were noted from the cover after the replacement but there was still oil spewing from the vent slits. My current thinking is that the oil is coming from the rear main or oil pan gasket, despite which one I figure the engine must come out to repair the problem. If you run the engine for about 4 hours it will loose about a half quart. If anyone knows (and this would save me a lot of time and money) if the rear main or oil pan gasket were leaking would the leak have the ability to make it to that part of the engine or is this part of the engine sealed from the rear main and oil pan gasket. If it is sealed I then need to look elsewhere like the rocker gasket, or oil sending unit. If someone knows this answer it would save me lots of headaches. I know that I am posting this under the props section, but my thinking was that the two gentlemen that got back to me about the prop may have knowledge of this particular situation.
Thanks,
John
