proper 2 cycle oil
graven
i've been told that older outboards such as the 61 johnson 35hp that I recently got takes a different oil than the newer ones. Is this true, and what would be a good oil and mix ratio?
Joe Reeves
Re: proper 2 cycle oil
Graven.... OMC Johnson/Evinrude did not make a 35hp in 1961 but I understand what you're asking. When OMC first came out with the 50/1 oil, they issued a bulletin that stated that is was safe to use the new 50/1 oil mixture on all of the engines they had manufactured, including the ones of yesteryear... excluding the older 7-1/2hp models.<br /><br />Many technicians state that the 50/1 mixture should not be used on any engine that does not incorporate needle bearings throughout the powerhead (con/rod, wrist pin, main bearings) and I can understand their reasoning. However, I am aware of many older engines in the 3hp, 5hp, etc that have been running the 50/1 mixture for years without encountering problems.<br /><br />A general rule of thumb is, if you know the engine has needle bearings through out, use the 50/1 (1pt to 6gal) mixture with confidence. If in doubt about the needle bearing setup, use the 24/1 mixture (1qt to 6gal).<br /><br />Should I ever come across the bulletin I mentioned, I'll post it.
rolmops
Good Evening<br />Your engine takes the exact same high grade 2 cycle oil as the modern ones.Factory recommendations for this engine are 1 quart of oil to 6 gallons of gas which means 1:24 mix.I use 1:32 on my own '57.Anything leaner than that will probably damage your engine.
graven
thanks Joe. when did the start or stop making the 35hp. the boat it is on is titled as a 61 and the former owner thought it was original. it is a red and white sea horse
graven
WOW, this just keeps getting better. a 61 boat,a 57/58 motor all for free :D
Joe Reeves
Graven.... Find and check the model number. A RD-19 is a 1957 (more red than white). A RD-19C is a 1958 (more white than red.)
petryshyn
Hi Joe Reeves <br />I'd love to see that bulletin. Please post it if you find it...<br />Thanks :)
