Proper Fuel water separator for a 125 ho Force
fishbait2
What is the correct fuel water separator for a 1988 Force 125 hp? Number? Type?
I would like to use 3/8 fuel line if possible
jerryjerry05
ANY one will work, the ones with the clear bowl will make you happy!!
Just finding a location will be tough??
Then install a small particle filter between the pump and the carbs.
Fram G-2 G-3 G-12 works well.
