PROPER GAS/OIL MIX I'M WET FOULING 89 J/E 40HP O/B
mar t G
I'M WET FOULING so i started a tune up compression checks even @127 on both then i did the plugs there new & gapped to 0.030 sequence calls for me to move to the lower unit and water pump then fuel system i don't have a VRO horn so there's no tell tale warning . without the horn how can i tell if it's mixing right<br />STAY AFLOAT<br />MAR T
D
DJ
Guest
Re: PROPER GAS/OIL MIX I'M WET FOULING 89 J/E 40HP O/B
Watch the oil useage on the oil tank. Draw a line on it and use that line as a guage.<br /><br />I would pre mix 50:1 (one pint TCW-3 oil to six gallons 87 octane gas) until I verified oil useage.<br /><br />by the way, ONLY use Champion plugs in that engine. You can gap them out to .040".
