Proper lifting of engine -92 175hp ???
93evinrude
Hi - I'd like to know the proper way to lift a 175 hp 1992 evinrude intruder(VE175GLENC) and is there more than one method? I need to lift it to install replacement steering cables. Can you please advise?<br /><br />Also - I am installing replacement dual rack teleflex cables. What type of lubricant do you use on the shaft at the motor end? I've heard differing opinions. Dealers around here seem to use triple guard grease but I've also heard that lithium is much better. Your opinions would be appreciated.<br /><br />Thank you
