Proper Mixing of Fuel in Side Tanks
SeaMasterZ@aol.com
It occurs to me that six gallon tanks wont cut it with big old motors, that 35 would yank down a tank in nothin flat, lol, running both engines would create a vaccum that opec would struggle to fill ...<br /><br />so if I put twin side tanks in, 18 gallon jobbers, how do you mix the fuel in stationary tanks? dump three quarts of oil in and blast the fuel in, let it self mix? even if I wasnted to pay the outrageous premix prices, they are mixed at 50 - 1, and of course, my ancient iron likes 24 - 1<br /><br />I like to have chaos in my mind at all times, something to think about<br /><br />4th of July is coming FAST!<br /><br />I suppose I could cheat and mount the electric motor on an wading tube .... course, where ya gonna put the battery? :eek:
Hopsdak
Re: Proper Mixing of Fuel in Side Tanks
Oh, Alright.. i didn't think to run it long enough for the t-stat to open.. Other than that it has good water pressure and it runs fine..
Jim_fwt
When mixing 2cycle oil and gas it is best to put in about of the 1/4 tank of gas in then add the oil, the finish filling the tank with gas.<br />When mixing oil and gas in larger tanks it is best to add the gas 6 gallons at a time so you can measure the oil corectly.<br />Good luck, Ji
Hooty
You probably knew this but, on the off chance you didn't, those big ole 35's will use approximately 10% of there rated hp per hour, @ wfo, of fuel or 3.5 gal./hr per engine.<br />I know, I know, more chaos. ;) <br /><br />c/6<br /><br />Hooty
SeaMasterZ@aol.com
wow, no I didnt know that ... hmmmmm, so that 125 is going to burn 12.5 gallons an hour ... Ummmm, Im gonna need bigger tanks, lol<br /><br />but for now, a day of cruising should be about a .. lemme see ... seven times eight or so, about 56 gallons ... and six into 56 is nine point something, so nine quearts of oil into the fifty six gallons of gas ... :eek: <br /><br />naught naught, carry the naught ... <br /><br />yikes!<br /><br />so that ten horse would burn ONE gallon an hour, hehehe ... ONE quart of oil ....<br /><br />ah well, gotta go broke on something, I spend money on wine women and song, might as well spend the rest foolishly!!!<br /><br /> :cool:
