Proper prop nut torque for an Alpha 1
Hello all i just purchessed a new prop for my Alpha 1 5.0L stern drive. I don't have a manual and wanted to know what the proper troque spec would be for the prop nut?
JB
Re: Proper prop nut torque for an Alpha 1
I/O topic
My Calibrated Elbow says about 50ft.lbs.......<br /><br />As long as it's Good,+ Snug....... And the Locks are bent over,.. You'll be Fine........<br /><br />Forward Thrust pushes the Prop On To the Shaft........<br /><br />The Prop Nut is only Working in Reverse.........<br /><br />Make SURE You Grease everything up Real Good........ It'll come off Easier,.. Later.......
cc lancer
My Calibrated Elbow says about 50ft.lbs.......<br /><br />Did you buy it.....Or-did-it-kinda-grow-on-ya! :D
Don S
Ya can't just buy em, they have to be calibrated with years of practice.
rabidfish
Mine's all worn out... ony gets to about 45 lb ft these days...
I'm Not Positive,.......<br /><br />But,.. I believe I stole that line from aChris........... :D
