Proper prop?
tjello327
I am looking for a good used prop so I can save some money. I found a couple on e-bay but they look like they are hollowed out in the hub area. My engine is a 1986 125 hp. force. I don't have thru the prop exhaust. Are these props that are hollowed out for thru exaust and will these work on my outboard? Thanks Forum!
jerryjerry05
Re: Proper prop?
They will work on it they just need different spacers and hardware.Make sure the pitch is the same.J
tjello327
Re: Proper prop?
do you mean the spacer behind the prop? Thanks Jerry
Dhadley
Re: Proper prop?
The thru hub exhaust props won't work on your motor.
