wysocki389
- Joined
- May 17, 2007
- 7
I just finished rebuilding three gunked carbs on a 75 HP ELPTO with the help of this forum and the service manual. Getting ready to put things back I see two sets of torque values for the air attenuator bolts/studs-nuts. In section 1 (Specs) they are called out at 100 in-lbs; in the power head section they are called out at 45 FT-lbs. That is quite a difference.
I put the carbs & air attenuator back and started torquing the nuts/bolts and noticed (using a steel ruler) a deflection across the air attenuator at 10 FT-lbs (120 in lbs). I stopped there not wanting to crack the attenuator or snap ears off the carbs.
45 FT-LBS seems very high given the reed block and cylinder heads are spec'd at 18 ft-lbs
any advice is very welcome
