Proper torque for prop nut
Seastarr Tex
I had to take my prop off in order to install a hydrofoil fin. This is a 1980 Mercruiser 470 outdrive. I thought the proper torque was 55lbs. Also, is it common for the prop to rest against the rest of the outdrive when the trim is in the up position
Re: Proper torque for prop nut
Ayuh,.. About 50ft.lbs. is about right...
No, the prop shouldn't be touching the housing,...
Could be the wrong thrust hub...
