Re: Propping my boat to stay on plain
Tabs both active and passive can be very effective,improving hole shot and keeping on plane at reduced power, improve ride, reduce no wake speed wander.
I hasitate to put holes in a boat below the water line and active tabs do add some complication to the boat and tabs do use ever so slightly more fuel unless fully retracted.
Hard to measure the difference.
A 4 blade will get you up quicker,and stay on plane at lower throttle with less fiddling.
It may also slightly improve ride and handle better at the dock. Usually there is a slight loss of speed but I have seen some that maintained speed and actually gain speed but it is the exception.It is usually suggested to drop one inch in pitch going to a 4 blade.
Just to clarify some on the tabs. Smart Tabs are passive. You adjust and test them after install, then forget about them. Manually controlled tabs, work like your trim adjustment, you adjust each side manually. These are active tabs.
IMO, active tabs are for big water, large wave type boating. You can adjust to multiple conditions. I wouldn't recommend them on a 17' bowrider running mainly on a river.
As far as hole below waterline, to me that is mainly a phych thing. After the first one, you realize that its not that bad. Be it tabs, transducer, swim platform, etc, eventually you will put a hole below the waterline. Like most things, do it it right with the right materials, and it won't be an issue.
Never thought about the gas milage before. Not sure if that applies to the smart tabs (outside of pre-planning speeds), but see if you left the active tabs down after being on plane, it would cause more drag, and lower milage slightly. I would think any prop that lowers wot speed also has impact on gas milage. I am not sure which has more impact? I've never really worried about gas milage pulling tubers, etc. Its going to be bad no matter what, and you don't want to think about it to detract from everyones fun!
