Props for flat bottom boats
Todd Humphreys
Currently I have a SS OMC 13x19 on my 1982 75hp Johnny on a fiberglass flat turning about 6000 rpms. I looking into purchasing a new SS prop from iboats, there are a few different types, some with high rake, some with vent holes, and others with cup. Good overall performace is preferred. Any suggestions is appreciated ie. express, rapture, .
Dhadley
Re: Props for flat bottom boats
We kind of assume youre looking at 3 blade props. We have had excellent results with Rakers, Stilettos and Turbos. If you dont have a jackplate of any kind I'd suggest an 18/20 Raker or a 19 Stiletto.
Todd Humphreys
3 blade yes. No jackplate. For what its worth, my X demension is 1/2" above the boat bottom. The problem I'm having is the prop ventalates on full throttle hole shots. Initial full throttle the bow rises and when the boat start to plane (bow starts to drop) ventalation occurs in which rpms rise to 5200 to 5400 and continues there until the WOT is reached. The prop is not slipping (put marks on hub and prop). Using a prop calculator my slippage is 15%. GPS 38 mph @ 5800 rpm. Should I get a new prop, rework the OMC, or lower the motor one hole to even with the bottom of boat?
mjbrueck
Flat bottoms like to ventilate, especially in turns, a heavy chop or changes in speed. A similar-sized, cupped prop would probably solve you're ventilating. If you don't mind losing a little top end, lowering the motor a little would also likely solve your problem without a prop change.
Todd Humphreys
The OMC 13X19 is definetly cupped, both on the pitch and rake lines (verified by reading the prop technology on mercury web site). The prop has some minor nicks on the leading edge. Also has home made vent holes about 1/4" on all three blades. There is no ventalation on turns, only if trying to accelerate with motor positively trimmed and during full throttle hole shot full negative trim. This motor is recently rebuilt 30 over pistons. Also has a hydrofoil.
Salmonseeker
There are vent holes on the actual blade or on the hub? I have heard of them on the hub, but not the blade.
Dhadley
With positive trim on acceleration we would expect some venting. Thats an old trick to get the r's up quicker. Helps sometimes when trying to get up in a hole in shallow water.<br /><br />Slight venting with full negative trim means the vent holes are working. If its more venting than you want, plug the holes completely or redrill the plug smaller.
Todd Humphreys
I'm leaning toward a 13 1/4 X 19 Rapture here on iboats, simply because the money I'll spend getting my OMC prop serviced is about the same price as the rapture prop. Thanks for all your input.
Todd Humphreys
Ok, since my last reply I still didn't buy a new prop (wife, kids, etc, etc.) I'm now ready to purchase a new prop. After months of deliberating and learning from these forums, I believe a higher thrust prop would be my best bet. Which would you choose, the SS Express(131/4x19) or the Michigan Match(13x19)?
Dhadley
Which would I choose?<br /><br />A Turbo Lightning Jr.
