props
gator-24
what is the difference in the prop diameters..like i have a 10 3/8x15 what would a 10 3/4 do any different...thanks
sony2001
Re: props
It would come 3/16" closer to the fin of the motor. Other than that,not much change in performance, if it has the same pitch. :cool:
Dhadley
Re: props
Generally speaking - a larger diameter allows for a higher X dimension (the motor can be mounted higher) which equals less drag. It will most likely "bite" harder or "grab" more water from the increased blade area.<br /><br />There is way more to it.<br /><br />Good luck!
