Props
So, just curious, can you use a mercruiser alpha one props on these motors? I recently bought a 26’ pontoon with a force 125 and I have a couple mercruiser props. Just curious if I could use them on the force. Haven’t found anything on this subject.
jimmbo
I don't think there is enough Space between the Propshaft and the Anti-Ventilation Plate to swing the Merc V6/Mercruiser Props.
Nordin
Maybe as jimmbo says and maybe the spacers between the housing and prop do not fit.
There has to be a collar at the prop that goes into the housing if there is a LU with dual exhaust (exhaust goes out in the centrum of prop).
I am not sure if the 125Hp had dual exhaust at some models.
