Re: Protective coatings for engine components?
I have por15 on my polished aluminum exhaust manifolds and have put it on mag wheels and chrome. I'll probably do my windshidld frame this winter at some point as well...
that's the glisten clear product - very impressive stuff in my experience. as is the hardnose I've used on some things.
and on coating passages... Bond's got it. anything you can imagine coating with, eventually the edge will delaminate from the metal and it will trap ions, etc... under. an issue for coating internal water passages is also that IF you put a significant coating, once it DOES start to come off, it is goign to help clog things up. for aluminum hard annodizing helps overall, but isn't bulletproof either.
cast iron, salt water -> rust not an easy way around it... especially on internal passages where you can't easily maintain and reapply coatings...
