Re: psi for 1989 110HP Johnson 2 stroke?
Overheating is about the only reason listed to give it a check, but mostly to see if you've got a blown gasket. Your numbers are even, so you don't. Overheating is more likely either waterpump, or thermostat related. A carboned up motor will run hotter at WOT, but your cooling system should keep up. Decarb is just a good idea, so you should do it anyway.
Sluggish starts are either starting procedure, carb, primer solenoid, or ignition related (in order of most to least likely).
In my experience, trouble holding an idle and degradation of hole-shot are the signs of a worn powerhead.
